Potable water tank monitor meter??
dsolo
454 EFI Crusaders
Name: La Belle ll
Been thanked: 25 times
Postby dsolo » May 5th, 2017, 7:57 am
Need help locating the meter for the potable water tank. Documents says the boat has one, I see the wiring coming from the water tank, just can't find the meter? Help again!
Dan
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
justavacation
Vessel Info: 2000 Carver 406 w/cummins 370hp
Re: Potable water tank monitor meter??
Postby justavacation » May 5th, 2017, 8:41 am
Hi, I have a 2000 406 and my water tank monitor is in the rear head next to the light/fan/head switches. Just under the counter top.
Been thanked: 646 times
Postby g36 » May 5th, 2017, 8:50 am
yep thats where it is on my 405 i also have a breaker in the main electrical panel for it
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » May 5th, 2017, 9:56 am
So I thought that was the waste tank monitor. OK thanks.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Postby g36 » May 5th, 2017, 12:39 pm
The waste monitor tank watch is the 3 or 4 lights panel the water monitor is a at leat oem round guage in the same vicinity . I almost hesitate to say after the inverter :-)
Take a look at this pic the water guage us on the far right below the counter top by the head
https://www.google.com/search?q=carver+ ... VrXRnwaCYM:
Been thanked: 246 times
Postby mjk1040 » May 5th, 2017, 3:21 pm
Hmm! On the 355 model it's in the galley, right of the stove, wonder why the put it back there on the 405's?
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » May 5th, 2017, 4:23 pm
Thanks to all. I will check it out this weekend. I plan on sanitizing the water system, per the method I read here, and using the water from the tank exclusively. The water monitor will be a valuable tool.
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » May 13th, 2017, 11:26 pm
Well found the meter right where g36 stated. Unfortunately it is not registering the tank level. It show's empty and the tank is full. Today while working on another problem I noticed alot of crosion on the wire terminals at the tank. I will clean them to see if it corrects the problem??
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » May 14th, 2017, 6:00 pm
dsolo wrote:Source of the post Well found the meter right where g36 stated. Unfortunately it is not registering the tank level. It show's empty and the tank is full. Today while working on another problem I noticed alot of crosion on the wire terminals at the tank. I will clean them to see if it corrects the problem??
Have a close look at the terminals on the tank, see if there are two small adjusting screws on the plate, if so then you can adjust the tank gage reading with those..full and mt..instructions would be in owners manual....I know ours has that, but have a look....... :beergood:
dsolo
454 EFI Crusaders
Name: La Belle ll
Postby dsolo » June 7th, 2017, 8:21 am
Following up on this post. Found the terminals heavily corroded. Scrapped and cleaned with contact cleaner. Adjusted the two pots back and forth. Had no effect on meter. Measured+12 vdc on power terminal and +8 vdc on other terminal. Adjusting pots did not vary voltage (+8vdc)
Does any know the mfg'r of this unit? Thanks
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
