3807 Icemaker shutoff
- VapinBill
- Vessel Info: New owner of a 1989 3807.
- Has thanked: 8 times
I have a 1989 3807 Aft Cabin with wetbar and icemaker.
is there a shutoff valve for the icemaker? If so, will it shutoff the faucet in the wet bar also?
Twin, Crusader 7.4L (454 cid V-8)
Detroit Michigan
Re: 3807 Icemaker shutoff
- VapinBill
I don't ever intend on using it and will remove the icemaker today and see how it's configured. Will keep you posted. Thanks again.
Detroit Michigan
- mjk1040
- Been thanked: 248 times
- VapinBill
I placed a shut valve on the main line going to the sink and icemaker.
Detroit Michigan
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
- Has thanked: 2 times
- Been thanked: 3 times
- rkrumm
- Vessel Info: 1995 430
- Has thanked: 1 time
Anacortes, WA
1995 Carver 430
- mjk1040
crquisto wrote:Source of the post I get a wet carpet beside aft deck ice maker/wet bar whenever water pressure is on for a while on my 406. Haven't been able to figure out how to remove the whole thing to look for the leak. I'm betting I can get help here. Thanks
What kind of unit do you have? Some have a lower front access panel that can be removed easily. There you can check if the water inlet valve or hose is leaking.
