310 Santego 5.0 liter twins
- Donald Claypoole
- Vessel Info: 1994 Carver Santego 310
Twin 5.0 liter Merc/Alpha I/O
37x hours, fourth owner, purchased October 2016 - Location: Erie, PA
- Has thanked: 2 times
Re: 310 Santego 5.0 liter twins
Second, I would look at one engine at a time. Start with the port, if its running rough. Not sure about your engine knowledge, but is it a rough idle or did some install a performance rebuild with a steep cam? If your not sure have someone do basic tune up procedure on both motors. Check the timing, and verify the firing order on the newer engine. They both should have electric ignition so no dwell to check, but timing advance would also keep you from planning.
- waybomb
- CYO Moderator
- Been thanked: 490 times
Sounds like somebody was extra cheap and installed a non-marine engine.
And did a poor job of it.
If the other engine grenades, what will you put in? You have no idea what the po idiot installed on the other side.
If walk away from this one. Who knows what other stupid things they did.
Your call. If the vessel is cheap and you can buy a new reman like the original, install it, and still be at what the vessel done right is worth, may be worth a chance.
- Donald Claypoole
- Donald Claypoole
- Been thanked: 1113 times
I would not replace a 4bbl with a 2bbl. You could lose a lot more performance than you think. I'd either replace the Holley (and perhaps intake) with a like-minded Rochester, or I'd replace the Rochester (and perhaps intake) with a similar Holley. Without specs on the engines though, you may never get them the same. Depending on how far they are really off... I might just deal with the difference until I opted to replace/rebuild one of the engines.
Where did he come up with the "approx 40 HP more" calc?
Users browsing this forum: No registered users and 40 guests
