Carver Riviera - navigation/interior lights not working (?)
- MikeL77
- Vessel Info: Carver Riviera 1987
Twin Crusader 305's - Location: Upsnake New York - Adirondack Mountains
- Has thanked: 1 time
I have a 1987 Carver Riviera and the navigation and interior lights are not working. There are separate circuits for each in the fuse panel. I do electrical work on my home, i.e. install sub-panels, circuit breakers, etc., but I am an utter novice with boats. Where do I even begin? Are there circuit breakers or fuses that may need replacing in the electrical panel itself? Shore power is working, and my receptacles all work, as well as most gauges on the operating console. A little hinky, but I am planning on cleaning up the ground points.
Any help would be appreciated.
Thanks,
Mike L.
- waybomb
- CYO Moderator
- Has thanked: 64 times
- Been thanked: 481 times
Re: Carver Riviera - navigation/interior lights not working (?)
- mjk1040
- Been thanked: 246 times
- Has thanked: 469 times
- Been thanked: 1765 times
- MikeL77
I'll start taking things apart soon. Should I disconnect the grounds from the batteries before messing around?
Thanks!
- waybomb
- CYO Moderator
I do not remember any fuses installed by carver. Everything was on breakers.
You have a switch for panel lighting on your helm check for voltage at the back. Four little screws hold on that aluminum piece the switch is mounted on. You can pull that little panel and check. If no voltage pull the dc panel out and check for voltage on the back of the breaker.
You could have a bad breaker
- MikeL77
