Engine Hour Meter Running Fast
- crquisto
- Vessel Info: 2000 Carver 406 Aft Cabin, twin 7.4 gas Mercruisers - Flyboy II
- Has thanked: 2 times
- Been thanked: 3 times
- waybomb
- CYO Moderator
- Been thanked: 490 times
Re: Engine Hour Meter Running Fast
I'm thinking getting a new one and just keeping the old one in case I ever sell the boat, in an effort to show why I changed it.
- waybomb
- CYO Moderator
In my case, the voltage as essentially the same. Within a tenth of each other.
They'll run as long as you have the key in the ON position so always remember to leave keys in the OFF position. You can try hooking up a cheap hour meter in parallel and check the difference in a few hours. If the cheap one keeps proper time over your existing one, replace the existing meter.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
RGrew176 wrote:Source of the post .....The other thing I noticed too on my boat is that the hour meters do not advance if one of the engines is not running. Both engines need to be running for them to click forward.
That's odd. I'm trying to figure out how that's even possible. Must be wired incorrectly. Once you apply 12 volts from one engine, the meter should run. Each should be wired into its corresponding RUN side of the ignition circuit. You'd have to combine both port and strb RUN circuits to get what you're describing which doesn't make sense or you wouldn't be able to shut off just one engine.
- RGrew176
Viper wrote:Source of the postRGrew176 wrote:Source of the post .....The other thing I noticed too on my boat is that the hour meters do not advance if one of the engines is not running. Both engines need to be running for them to click forward.
For some reason that is how it is set up. Could be the original set up or perhaps one of the two previous owners changed something. As long as they work reasonably well I am satisfied.
- crquisto
- Been thanked: 1113 times
crquisto wrote:Source of the post Well, folk, I believe I've found the problem and it's me. I left my ignition switch on a during the time in question after taking some fuel readings in port.
Been there, done that!!! Took some fuel readings in the evening (which requires port engine ignition) then left the switch on overnight. +12 hrs on the engine!
Users browsing this forum: MrMojoRisin and 31 guests
