Hot water tank pressure regulator spraying hot steamy water
- dsolo
- Vessel Info: 1997 Carver 405 MY
454 EFI Crusaders
Name: La Belle ll - Location: Onekama, Michigan
- Has thanked: 68 times
- Been thanked: 25 times
Any help would be appreciated. Boat is new to me, still learning.
Dan
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
- waybomb
- CYO Moderator
- Has thanked: 64 times
- Been thanked: 481 times
Re: Hot water tank pressure regulator spraying hot steamy water
If hot steamy was coming out, I would bet your thermostat let the temp get up over 212f - very dangerous.
- Been thanked: 601 times
The relief valve works opens on high temp and / or high pressure, so if the stat doesn't turn off the heat it will open.
- mjk1040
- Been thanked: 246 times
- Has thanked: 598 times
- Been thanked: 1281 times
- mjk1040
- Has thanked: 468 times
- Been thanked: 1765 times
The only amount of pressure that should be in the hot water tank when it's cold, is your fresh water system or dockside water pressures.
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
2022 Stingray 182 SC
- dsolo
454 EFI Crusaders
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
