Looking for a gear linkage for a 1988 Voyager 28
Topic author New Zealand
Darkfaythe
Vessel Info: 1988 Carver Voyager 28
Postby Darkfaythe » June 29th, 2017, 3:35 am
Hi all
I dont know if this is the right place to be asking this but I have a 1988 Voyager 28 with twin Chev 305's and V Drives.
One of the linkages from the V Drive to the prop shaft is bent and I'm trying to find a replacement.
It is a Walter V-Drive with 1 1?4" shaft and standard SAE taper with 5/16" key.
Does anyone have any suggestions please?
Cheers
Rob
Re: Looking for a gear linkage for a 1988 Voyager 28
Postby mjk1040 » June 29th, 2017, 5:26 am
Rob do u have a picture? How did it get bent? Is this in the boat or under the boat. Need more info here!
Darkfaythe
Postby Darkfaythe » June 29th, 2017, 6:01 am
Hi Mike
I have attached a graphic from the manual outlining the prop shaft coupling and thats the bit that seems to have worn 'out of true' from when the previous owner put it in crooked.
I can access this from in the boat so no problem there and its currently on its mooring anyway.
Hope this helps. I can photograph the segment when I go over the to boat on the weekend if necessary though.
Cheers
Rob
dsolo
454 EFI Crusaders
Name: La Belle ll
Been thanked: 25 times
Postby dsolo » June 29th, 2017, 6:25 am
If it is the shaft coupler you need they are replaced by supplying the specs:
Shaft size
Flange diameter
Couple type, tapper, split, reverse taper, etc.
Transmission type
A good prop shop should match a replacement. Go on line and search "inboard shaft coupler"
dsolo
Vessel "LaBelle"
1997 Carver 405 MY
454 EFI Crusaders
Darkfaythe
Postby Darkfaythe » June 29th, 2017, 6:39 am
Hi
Thanks for that. Both myself and my mechanic have been unable to find anything here in New Zealand hence my trying a little further afield.
It is a Walter V-Drive with 1 1/4" shaft and standard SAE taper with 5/16" key.
Cheers
Rob
Postby Viper » June 29th, 2017, 7:19 am
You're looking for a shaft coupler. Like dsolo said, a good prop shop should be able to help and ship one to you. Maybe one of the guys here from the States can recommend a good shop on this side of the pond or you can try United Propeller in Ontario Canada: http://www.unitedpropeller.ca/ ask for Amanda, I deal with her all the time, she knows her stuff. You can also try the Walter Machine Co. http://www.waltergear.com/.
If it's in the condition you describe, unfortunately you may need to dress/machine the tranny flange. If it's warped as a result of the coupler's condition, you need to make sure that gets corrected first. It would have to come off and sent into a shop to be refaced or you'll still have a vibration no matter what you do.
Darkfaythe
Postby Darkfaythe » June 29th, 2017, 4:12 pm
Many thanks for all your help people. I know have some good leads to follow up on. :approve: :approve:
Postby bud37 » June 29th, 2017, 5:10 pm
If all else fails in your search, I would probably take both sides of the coupling to a machine shop, I am sure they could make that stuff up for you....they understand taper fits etc....just a thought..... :beergood:
Darkfaythe
Postby Darkfaythe » June 29th, 2017, 5:23 pm
Yes, I know what you are suggesting. I have already done that with the prop shaft. THat has been machined spot on before re fitting it into the boat as I replaced the stuffing box at the same time, so its just the shaft coupler now. I am following up on the suggestions above for that right now.
Postby mjk1040 » June 29th, 2017, 5:53 pm
Ok, glad all worked out. When you first said linkage instead of coupler I was puzzled. It concerns me how that got so out of shape to begin with, whatever it has to be fixed now. Good Luck!
