Type of oil?
Topic author Italy
Bankerbiz87
Vessel Info: 1982 Carver Mariner twin 220 engines 28ft
Type of oil?
Postby Bankerbiz87 » July 4th, 2017, 11:13 am
We have 2 350 engines Crusaders should we be using a synthetic oil?
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Re: Type of oil?
Postby SplashyLady » July 4th, 2017, 11:52 am
Rotella 15-40 seems very popular with boat users and is priced reasonably at most retail locations. :down:
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Been thanked: 490 times
Re: Type of oil?
Postby waybomb » July 4th, 2017, 12:38 pm
X2 on Rotella.
throwback2
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Re: Type of oil?
Postby throwback2 » July 4th, 2017, 3:52 pm
X3 .That's what I use too.
feeez
Vessel Info: 2001 350 Mariner
Has thanked: 52 times
Been thanked: 66 times
Re: Type of oil?
Postby feeez » July 4th, 2017, 4:40 pm
X4..... switched last year
Former 2001 350 Mariner owner
Re: Type of oil?
Postby Viper » July 4th, 2017, 8:24 pm
Bankerbiz87 wrote:Source of the post ....should we be using a synthetic oil?
The answer is a complicated one and depends on several variables, however, in general for your vintage and typical recreational use, it's really not necessary. Save your money, use a decent quality oil, and change it at regular intervals.
Re: Type of oil?
Postby RGrew176 » July 4th, 2017, 10:25 pm
The marina where I am now located uses a synthetic blend oil.
Re: Type of oil?
Postby mjk1040 » July 5th, 2017, 7:38 am
Rotella! Comes in 30W, 40W and 15w40. Tractor supply stores carry it at the best price IMO!
Re: Type of oil?
Postby km1125 » July 5th, 2017, 8:20 am
As other say, the Rotella is very popular and has tested well - and is pretty economical to run. I personally use Mobil1 15-50 but mostly because I use it in everything else I run (at different weights). Impressive cold-start performance (but not nearly the issue in boats). I was sold on it years ago when I tore down a very-hard-run turbo motor at 165,000 miles and it looked like new.
Also, a recommendation when you're referring to your motors: Crusader also makes a 454 that is labelled "350 HP", so it gets confusing when you refer to a "350 Crusader"... you should make it clear that it's a 350 CI if asking questions or getting parts for it.
Re: Type of oil?
Postby tomschauer » July 5th, 2017, 10:56 pm
+1 on the Mobile 1. I run it in everything I own. Very slick and bullet proof.
If you switch from conventional to synthetic, the first run of synthetic will clean a lot of the sludge from your engine and make the oil look pretty dirty pretty quick. After the first synthetic change, odds are it will never look dirty again unless you put several hundred hours on a year.
