Replacing dead HVAC units on a 370 Aft Cabin
- gmwalley
- Vessel Info: 1994 Carver 370 Aft Cabin
- Been thanked: 11 times
A couple of notes:
1) No where in the install instructions does it tell you anything about the return air sensor, left it coiled up inside the electronics box and you could hang meat in the cabin after a hour or so. Manufacturer is adding notes in the manual for future. Of course after talking to vendor and looking for the sensor - duh! everything is working fine now.
2) On my boat the freshwater tank is plumbed to the flush water supply inlet to both toilets! Boat documentations says there are thru-hulls, but not on my boat. Always wondered why we ran low on freshwater so quickly. Good news is since toilets are flushed with potable water - no river stink!
3) It takes a heat gun to soften the hoses to pull them off the hose barbs (and to put them back on).
4) New unit raw water fittings are 3/4" and boat hose is 5/8". Webasto provides cheesy plastic adapters (no hose clamps) that I had trouble getting to seal up with no leaks. I went to a hydraulic hose shop here in town and built some adapters out of good brass fittings. Flows better and no leaks!
5) Be prepared to fabricate adapter flanges to mate to the existing conditioned air manifold - of course flange doesn't match the old Marineair unit.
- Killin time
- Vessel Info: 1996 355 Aft Cabin
- Has thanked: 20 times
Re: Replacing dead HVAC units on a 370 Aft Cabin
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
2022 Stingray 182 SC
Users browsing this forum: No registered users and 7 guests
