Exhaust Mufflers for 3607 Carver
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
- Been thanked: 1113 times
Re: Exhaust Mufflers for 3607 Carver
I wish I had done some kind of before-and-after test. I had put them in over the winter so I couldn't really judge how much of a difference they made. I took them out because I thought there was too much back pressure... I had an exhaust hose pop off and I blamed it on them. It was probably just bad clamps though.
Underwater exhaust will require a muffler specifically designed for that. They typically have a dry exhaust relief above the waterline as well. They're okay but I always prefer to see at a glance that I'm actually pumping water. Also not crazy about a couple of large holes in the bottom of my hull. Having said that, while mine isn't underwater exhaust, it's not that easy to tell if I'm pumping or not.
My 3807 doesn't have mufflers either. It's on my bucket list but will be a bit of a challenge to incorporate. There isn't much room between the Y fitting and where the exhaust hooks up to the hull side. There is an exhaust pocket built/glassed into the hull that runs from the engine compartment to the transom so there is no way to install an inline muffler along that run. Also very little room in the engine bay for a lift muffler. Centek makes some smaller in-line units that will fit between the y and the hull side but the smaller you go, the less effective they are. Going to be a bit of a challenge to get a meaningful difference but I'll come up with something. May go with an exhaust hose insert type like this, they can be installed in a flexible exhaust hose and clamped in place.The good think is it doesn't matter if the hose is level or not which really makes a difference in my case:
https://www.wr-products.com/products/ggb-marine-exhaust-insert-competition-4-pair
- MakinTime
Those bolt-on mufflers look interesting. I wonder how well they work.
Those integral ones that Viper linked to are interesting also. I wonder if it would work better to put two 3" ones in each exhaust output downstream of the risers or a 4" one in the main somewhere after they are combined?
I've looked at some custom ones that would have two 3" inputs and one 4" output.. there are a few designs that would fit behind my engines above the shaft log but haven't explored it beyond looking at pictures.
