porthole screening
- Scienceguy
- Vessel Info: 2000 Carver 406 aft cabin
- Been thanked: 2 times
porthole screening
Does anyone know what glue material Carver used to hold the rubber gasket and screen into the porthole?
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Re: porthole screening
- cpoint
Viper wrote:Source of the post Sikaflex makes a 295 UV product which is a UV resistant adhesive sealant
Thanks Viper. Looks like they don't have a small batch. I only need it for one port hole. I'll check to see if I can use this for other purposes on the deck. I do need to reseal some parts, if this works for that then it is worth getting the large one.
- cpoint
michelml54
- Vessel Info: carver 325 motor yacht 1998
Scienceguy wrote:Source of the post Hi,
question: can you tell me what was the procedure you
question : what is the procedure to remove the old screen . Ihave a 325 carver and your screen looks the same and i do not know how to start to remove it
Users browsing this forum: Carverlvr2 and 29 guests
