Carberator
Topic author Italy
Bankerbiz87
Vessel Info: 1982 Carver Mariner twin 220 engines 28ft
Carberator
Postby Bankerbiz87 » August 28th, 2017, 7:17 am
[image][/image]
We Need to replace the carborator our engine is a Crusader 220 with 305 1982 Carver
We would like to find a rebuilt carb to keep cost down any idea where we can get the carb
Or search for a carb
Re: Carberator
Postby g36 » August 28th, 2017, 8:53 am
hard to say what carb you have since the flame arrestor is covering it. why do you think you need carb rebuilt? what is it doing?. if you want to keep cost down you can do it yourself, theres really not much there to clean and rebuild or take yours to a place local to you most likely a garage by you that can do it or tell you where to go and have them rebuild it probably cheaper than purchasing a rebuilt one.
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Re: Carberator
Postby SplashyLady » August 28th, 2017, 8:59 am
Looks like a Rochester Quadrajet. You can replace it or get it rebuilt by a good carb shop. I would suggest rebuild, but Q-Jets are tricky, so unless you are pretty good, don't try it yourself. Getting all the jets and metering rods right can be difficult, but you won't have to worry about that with a rebuild, because they will keep the same setup. Q-Jet overhaul is not easy, so expect to pay $150-$200 for a quality rebuild - and don't go to a shade tree guy on this - find someone who knows how to overhaul a Quadrajet.
Also, there is usually a metal tag under one of the screws on the top of the carburetor. That tag has a number on it that tells you the specific model of carburetor - you can usually get an exact match if you have the number. If you decide on a replacement, expect to pay around $250 for a rebuilt, and $350-$400 for a new marine carburetor. Note it is important to get the marine version for your boat!
http://www.jegs.com/webapp/wcs/stores/s ... &langId=-1
Hope this helps - good luck!
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Re: Carberator
Postby mjk1040 » August 28th, 2017, 6:47 pm
Do them both, not just one!
Australia
Golfgippsland
Vessel Info: 1989 Santego 2767 mid cabin express
Been thanked: 2 times
Re: Carberator
Postby Golfgippsland » August 29th, 2017, 3:39 am
Definitely make sure you replace with marine quadrajets or marine overhaul kits there is a difference from the auto quadrajet. I have seen people on auction sites trying to pass off auto as marine!! As said previously check the numbers.
Gippsland lakes Australia
1989 Carver 2767 Santego
1971 v156 glastron modified
1985 whittley cruisemaster
1982 2950 Bayliner offshore express
CoreDuo2
Vessel Info: Carver 3227 convertible
Has thanked: 3 times
Re: Carberator
Postby CoreDuo2 » September 20th, 2017, 1:53 am
Please help me to find someone who can rebild my rochester Qjet carb.
because it is very hard to find in Russia professional company or man who can to do it.
Re: Carberator
Postby mjk1040 » September 20th, 2017, 7:23 am
CoreDuo; U may be better off buying new carbs if your carbs are very old. The cross shafts tend to wear out and leak thus not worth rebuilding.
