Hot Water Tank
eburklo
Vessel Info: 2003 Carver 564
Hot Water Tank
Postby eburklo » September 7th, 2017, 10:32 am
My 2003 Carver 564 Hot Water tank needs replacement. My unit is the Sealand Model 1900E. The tank is too large to remove between the engine and generator. Any ideas, can the floor be removed?
Has thanked: 469 times
Been thanked: 1765 times
Re: Hot Water Tank
Postby Viper » September 8th, 2017, 7:27 am
I can't offer anything on accessibility but why does it need to be removed? What's wrong with it? Except for a leaking tank, everything else can be repaired.
Look above the tank, if there is access through the floor that might be covered by carpet, you may see evidence of a hatch above the unit.
