Bildge Blowers/Ventilation
- LDT24/7
- Vessel Info: 1984 Carver 3607
Crusader 454's Velvet Drives
Westerbeke 8Kw Gen - Location: Texas
- Been thanked: 1113 times
Re: Bildge Blowers/Ventilation
- waybomb
- CYO Moderator
- Been thanked: 491 times
But if you smell gas, you have a leak somewhere. You should not smell gas.
Have you filled the fuel tanks recently? If so, check your fuel fill hoses from the deck fitting to the tank. They tend to crack with age. While you're there, check the vent hoses as well. Other than that, your tanks or the delivery system from the tanks to the engine are suspect including fuel lines, fittings, selector valves, filter assemblies, etc. On your engines, check the fuel pumps and the lines leading from them to the carbs including the small clear one. Also check your carbs for wet/leaking gaskets. With the engines off, try to look down the throat of the carbs to see if the intake manifold is wet. Pull your dipsticks, note the oil level, and check to see if the oil smells like fuel.
- waybomb
- CYO Moderator
You have a leak someplace. I think viper hit them all.
Go to youtube and look up boat explosions; they were all caused by leaking gas.
Yes, I am attempting to scare you. This is scary stuff.
Don't know how you'd be getting an exhaust smell without the engines running unless windows are open and neighbouring exhaust is making its way into your cabin when the wind is blowing just right. That could linger in your cabin for a while.
Curious; if you smell fuel or exhaust, are CO and fume alarms not going off? If not, why not??
Users browsing this forum: Beachlovers, Google Adsense [Bot] and 26 guests
