Until last week there were no problems. Last week it was a brief problem. this week I did not want to force it too much and end up with a bigger problem. This is on a carver 356 aft by the way with gas mercur engines.Welcome to Carver Yachts Owners Forum
Cant shift gear for starboard side
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
Until last week there were no problems. Last week it was a brief problem. this week I did not want to force it too much and end up with a bigger problem. This is on a carver 356 aft by the way with gas mercur engines.-
- Has thanked: 474 times
Re: Cant shift gear for starboard side
- cpoint
Viper wrote:Source of the post Check to see if there is oil in the tranny. You should see a dipstick on the top right area of the tranny. On the side of the tranny, you'll see where the shift cable hooks up. Remove the cable and try to move the lever by hand. It should move. If it doesn't, you'll likely need to have the unit removed for assessment and repairs.
Viper Thanks, will check
- cpoint
- Dewmyster
- Vessel Info: 1998 370 Voyager
- Been thanked: 12 times
- cpoint
Dewmyster wrote:Source of the post Check out my saga under Gas Engines/Transmissions.......not a happy ending.
Trust me my saga is not good to start with, so nothing surprises me at this point, still working on the original issues since last year. But I am hoping this is just a cable issue or something, not that it will cheap I am sure even if it is the simplest thing
- cpoint
- cpoint
- cpoint
