405 Raw Water Pump
- GarryD
- Vessel Info: Carver 405, 1999 model, twin Cummins 375hp engines,
405 Raw Water Pump
Does anyone know if a remote belt driven raw water pump is available for the Cummins 5.9 BT6 Diesel engine.
I have no trouble changing the starboard engine pump but cannot get to the port engine pump on my 405, just not enough space between engine and fuel tank. Have thought of squeezing under the engine from the front but don't know if I will ever get out.
Would be grateful for any help.
- mjk1040
- Been thanked: 248 times
Re: 405 Raw Water Pump
- Has thanked: 602 times
- Been thanked: 1310 times
On a lighter note you could maybe hire E.T.....3 ft tall and 5 ft arms...I'm kidding.....
- GarryD
I have noticed fixings holes in the block near the fuel manifold, if I source a belt driven pump and mount it on a bracket here and change the crank belt pulley for a double unit might be able to drive it from there. I will speak to Sherwood as you suggest.
Also can't believe you have to raise the engine on the mounts to remove the pump.
- hausherrs
- Vessel Info: 1996 Carver 400
- Has thanked: 5 times
- Been thanked: 10 times
Im 6'4 and 240+ lbs. I had no trouble getting in there. Getting out was a problem when my legs turned to jelly from all the cramps.
- GarryD
