Carver Mariner Engine Room insulation
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Postby amanphoto » October 18th, 2017, 6:31 pm
I want to replace the foam on the hatches in the engine compartment. They hold water. What else could I use for insulation in the engine compartment?
Has thanked: 603 times
Re: Carver Mariner Engine Room insulation
Postby bud37 » October 18th, 2017, 8:43 pm
Whatever you decide on ,it will have to have the proper fire rating....my boat has the same problem on the port side.....much of it seems to get in from under the hatch pull......I have put a gasket under the pull on the deck side with a light compression spring underneath to keep pressure on the pull gasket...this has helped a lot so far. Going to improve it in the spring , parking lot tomorrow .Thats enough this year.
Postby tomschauer » October 18th, 2017, 8:59 pm
I don't think any of the egg carton foam has a fire rating (it should) Cut a piece, remove from the boat and other valuable possessions and hold a lighter to it, if its dry, stand back!!!
Consider using a dense fiberglass such as HVAC 1" duct board. Fire resistant and will not hold water like the foam.
Been thanked: 285 times
Postby buster53 » October 19th, 2017, 12:10 pm
Google is your friend. Try "marine engine room insulation" Lots will pop up, but it ain't cheap because it is made specifically for that harsh environment.
