What is this and where does it go?
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
Note: My hot water heater works great. The hoses from the port engine that supply engine heat are connected and working. Its to small to thread into the pressure relief valve. My drain on the hot water tank is female also so this could not thread into that.
Before I start taking things apart, I was wondering if you all had an idea.
- Has thanked: 603 times
- Been thanked: 1311 times
Re: What is this and where does it go?
- daveS
- Vessel Info: ☀️Sanity Sol☀️
1999 350 Mariner - Location: Penetanguishene, Ontario
- Has thanked: 24 times
- Been thanked: 8 times
Looks like release valve hose
- amanphoto
I was under the impression that nothing should be connected to the relief valve. It could cause a restriction and course the unit to blow up.
amanphoto wrote:Source of the post Yes the relief valve is open. I opened it to drain the water tank for winter.
A hose connected to it is fine and will not cause an issue whatsoever.
Midnightsun wrote:Source of the postamanphoto wrote:Source of the post Yes the relief valve is open. I opened it to drain the water tank for winter.
+1 Yup....check out your water heater at home.
amanphoto wrote:Source of the post.......I was under the impression that nothing should be connected to the relief valve. It could cause a restriction and course the unit to blow up.
Nope. That's why the discharge port on the valve is threaded. They wouldn't do that if they didn't want anything hooked up to it.
- mjk1040
- Been thanked: 248 times
