Carver 3607 door slides
MakinTime
Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo
Has thanked: 52 times
Been thanked: 31 times
Postby MakinTime » January 2nd, 2018, 6:41 pm
My cabin sliding door going downstairs has always been tougher then I like when pulling it shut or opening it up, so I pulled it off last weekend and found a broken plastic slide that was probably making it tough. Also I wanted to refinish the door but there are just to many deep scratches in the wood top veneer so I am building a new door.
Finding the slides and tracks I need has been kind of tricky. Has anyone dealt with this on a 3607?
I will attach a pic of some door track and slides I found online but I would like other options. Any opinions on this? Some type of linear slide I think would work best but I dont know what to search online!
Re: Carver 3607 door slides
Postby km1125 » January 3rd, 2018, 8:05 pm
What year is your 3607? Do you have the horizontal panel that slides forward under the helm seat? The earlier ones were like that but the later ones had a higher door with a different panel on top. Don't know exactly how those worked.
I have 1983. I have removed the panel and rebuilt it years ago... just replaced some of the teak around the sides. I didn't have a problem with the track or slides that were in it, but the two caps at the end cracked up. I made a couple replacements out of Corian but haven't put them on yet.
MakinTime
Postby MakinTime » January 5th, 2018, 6:54 am
Thanks for the response, mine is a 85 and it slides under the helm. I guess I am looking for a “Home Depot” slide solution other then spending $300 for the slides I listed above.
Postby bud37 » January 5th, 2018, 6:56 pm
I think if I was retrofitting a sliding door, I might try to use a slide system that runs on a surface track and would be accessible for cleaning/maintenance, adjustment etc.........some people have been successful getting replacement parts from the box/ hardware stores. Should be lots of stuff for patio doors, have you considered a system like that ?
Something like this......https://www.primeline.net/product-categ ... r-hardware
MakinTime
Postby MakinTime » January 6th, 2018, 9:02 am
I have not considered this! I like the idea, I will be going to Menards today to check this type of rolller and track system out!
