Port Engine Overheating
- RickieT
- Vessel Info: Carver 350 Mariner 1997
- Has thanked: 18 times
- Been thanked: 3 times
- Contact:
Bought my first boat!!! Very excited and want to learn to do my own repairs, if at all possible. Have a 1997 350 Mariner with a 2 Crusader 350 XL engines. Starboard engine temp is perfect and port engine overheats when over 2200. Had a mechanic come in fill coolant check hoses and replaced both engine's impellers thinking that would do the trick. It's a little better but still overheats and white smoke emits from port engine. I'm thinking of trying Sea Flush with Barnacle buster or Salt Away on my own as a next troubleshooting step and last resort replacing the riser(s). Those are big bucks come to find out. I've been watching you tube videos on this process. Anyone have a link or tips for flushing all the crap that may be in the engine making it overheat? Do I need to remove the impellers when doing this chemical flush? Before I purchased the boat it had sat for a long while...
Many thanks
Rick
- mjk1040
- Been thanked: 248 times
Re: Port Engine Overheating
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
Also, rod out the Heat Exchanger and replace the U-cooler.
You didn't post much info about your motors so I'm going with what I did on my Mariner.
- Has thanked: 602 times
- Been thanked: 1310 times
edit , spellcheck correction....
- RickieT
- Contact:
RickieT wrote:Source of the post Greetings,
Many thanks
Rick
- RickieT
- Contact:
Many thanks
Rick
- RickieT
- Contact:
- RickieT
- Contact:
mjk1040 wrote:Source of the post OK Rick; I assume u have closed cooling by ur narrative. White smoke suggest u are burning the antifreeze. Head or intake gasket is bad. A cooler is bad and letting anti freeze into the exhaust via the raw water system. Does ur antifreeze level drop over time? Now ur in salt water I take it and replacing exhaust manifolds is common about every 5 years or so. How long did it sit on the dry? Can u post a pic of the smoke sometime? The Barnacle buster etc. can just be put in a pail and sucked in with the fresh water pumps. Let it stand in the engine for a good period of time, then just fire it up to flush out the junk. But as I said true white smoke indicates ur burning antifreeze. Keep us posted.
The boat just wasn't used a lot...it wasn't out of the water at all for a long period of time.
- throwback2
- Vessel Info: 1987 Carver 28 Voyager,twin small blocks,1991 Shamrock,350 Chevy now.
and a few other water toys - Has thanked: 8 times
- Been thanked: 23 times
- RickieT
- Contact:
I think this is steam...I posted a youtube video of it and my gauges at the time it was overheating...it is in salt water...San Francisco Bay
