1995 Carver 390 aft cabin to cockpit lock replacement
Jim L
Vessel Info: 1995 Carver 390 CPMY
Postby Jim L » February 1st, 2018, 3:50 pm
Hi all, I'm looking to either repair, or most likely, to replace the lock on the sliding aft cabin to cocpit door. Lock tumbler moves in and out, and then captures the key, making it very hard to remove; obviously internal breakage. Anyone know where to get a replacement or have had a successful repair? Thanks! Jim
Re: 1995 Carver 390 aft cabin to cockpit lock replacement
Postby g36 » February 1st, 2018, 5:53 pm
My carver locks are from perko maybe google their info should be able to replace the locks easy enough. If not you could call carver and they can tell you who supplied it
Postby Viper » February 1st, 2018, 9:29 pm
It's probably a Mobella (Southco). As mentioned, call Carver with your hull number and they'll give you the part number and supplier.
Jim L
Postby Jim L » February 2nd, 2018, 9:21 pm
Viper wrote:Source of the post It's probably a Mobella (Southco). As mentioned, call Carver with your hull number and they'll give you the part number and supplier.
Looks like they are made by Adam Rite, discovered that when I pulled it apart. Carver gave me a part number, but it wasn't the right one, or the right manufacturer (Pompanett, they thought or Southco). Of course they may have bought Southco or whomever...confusing. BL, took it to a local locksmith, and they were able to order a new cyclinder for $35. plus shipping from Adam Rite. Cheapest thing on the boat! Appreciate the response, Jim
Jim L
Postby Jim L » February 2nd, 2018, 9:23 pm
g36 wrote:Source of the post My carver locks are from perko maybe google their info should be able to replace the locks easy enough. If not you could call carver and they can tell you who supplied it
Thanks for the response, not Perko, see my response to Viper below----made by Adam Rite, got away with a cheap fix for a change!! Jim
RaRa
Vessel Info: 1990 Carver 32 Montego
Has thanked: 18 times
Postby RaRa » March 11th, 2018, 2:09 pm
I had a Lamp barrel lock on my 1989 Montego 3257. There turned out to be a distributor for builder hardware in Houston. They had it in stock. I made the trip across town and popped it right into boat. I wish everything was this easy!
1989 Montego 3257 @ Galveston Yacht Basin
