Navi lights not working now.
- RickieT
- Vessel Info: Carver 350 Mariner 1997
- Has thanked: 18 times
- Been thanked: 3 times
- Contact:
Trying to troubleshoot my navi lights on bow and white light up top on arch not turning on. Neither are turning on and my bridge lights and instrument lights all work fine. Can't imagine all 3 bulbs went out at the same time...checked to make sure it was turned on in the panel below the TV in the salon and it's on. Are there fuses some where I can look to see if that's the issue? I have a 1997 350 Mariner...
Many thanks!
Rick
Re: Navi lights not working now.
- mjk1040
- Been thanked: 248 times
If you have voltage at the fixture, use a piece of steel wool or fine sandpaper and polish the contacts and the end of the bulbs (if the bulbs are good). Also carefully bend to contacts in a bit to keep more pressure on the bulb. A tiny bit of dielectric grease can help prolong the maintenance intervals.
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
Cleaned them up and spread very little dielectric grease on the ends.
Once she's out of the shop, I'm replacing the anchor lights with LED bulbs.
- RickieT
- Contact:
Users browsing this forum: No registered users and 62 guests
