I have a 1999 Crver 356 with dual 440 engines. Under full power there is less than 3500 rpm's. Is that normal?
korchinsky
Vessel Info: 1999 Carver 356
Postby korchinsky » February 20th, 2018, 1:13 pm
Under full power I cannot get over 3300 rpm's. Is that normal?
Re: I have a 1999 Crver 356 with dual 440 engines. Under full power there is less than 3500 rpm's. Is that normal?
Postby mjk1040 » February 20th, 2018, 3:02 pm
No that is not normal, however if the props got changed for more low rpm thrust, you would lose top end rpms. Our 1998 355 with twin 454 ci engines top out at 4,400 rpms. We are going to need more info to help you here I'm afraid. You say 440 engines? Is that CI or HP? Is this a new boat to you or is this an issue that just happened on a boat you have had for awhile? Have all the fuel filters been changed? Since you said both engines only go tp 3,300 rpm's it may not be fuel. More Info and we'll see if we can help you with your issue!
Postby bud37 » February 20th, 2018, 3:17 pm
Welcome to the forum.....Also, I guess the simple answer is no......but if you are on salt water, is the bottom clean ?? there is enough drag from that to create your complaint.
Postby Viper » February 20th, 2018, 10:06 pm
Welcome aboard
First we need correct engine info, unless she's been re-powered with older engines, I'm pretty sure you don't have Chrysler 440 engines. Do you have Yanmar diesels?
The rpm on 440 gasers would be higher but pretty sure 3500 is about right for the Yanmars, maybe even a little lower. Would have to confirm but 3300 sounds right.
Postby tomschauer » February 20th, 2018, 10:17 pm
As others have mentioned, please provide more info on your engines. If not sure what you have take pictures and post them.
If they are diesels, 3500 rpm is pushing them hard. If they are gas, 454, 7.4 liter or 502, 8.2 liter they should do 4400 rpms.
Postby tomschauer » February 20th, 2018, 10:20 pm
Also, if you have 440hp diesels at 3500 rpm, that boat should be MOVING pretty fast!!! I would guess 34-35 mph. If you are getting that you are doing great!
Been thanked: 285 times
Postby buster53 » February 22nd, 2018, 11:16 am
Doesn't Cummins make a 440? Lot of engine for a 356.
Edit...
It just dawned on me, this is the gas engines forum. Being a '99, I'm guessing the OP has 454's.
If they are 454's, 3300 is way low.
Biggest culprits:
Bottom growth - barnacles
Wrong propellers
engine not running good.
My money is on #1, maybe #2
