LMS 350a Upgrade
- Iceagetech
- Vessel Info: 1987 Carver 2827 Voyager
Twin Crusader 220HP Inboards - Location: Wabasha, MN
- Has thanked: 2 times
- Been thanked: 11 times
LMS 350a Upgrade
- Has thanked: 602 times
- Been thanked: 1310 times
Re: LMS 350a Upgrade
I bought a Raymarine A97 two years ago. It has about 10 million features. I use about 5 of them. I have had Garmin, Lowrance, Northstar and Standard Horizon in the past. I don't believe Standard makes chart plotters any longer, I liked the 10" standard I had about 2001.
I like may Raymarine, but I believe the Garmin units are more user friendly, especially for basic features.
Not sure who made your LMS 350, but odds are if it is from the '80's the antenna and the transducer will not be compatible with a new unit.
That being said, if you mount it on the bridge a unit with an internal antenna will do the trick. If you just want depth and not worried about fish or structure you may be able to adapt your existing transducer to work with a new non CHIRP unit. Speed will be provided via gps.
Hopefully I helped a bit.
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
- Iceagetech
I have two helms but I only use the fly bridge. So I need the unit on fly bridge and need wires run. I am sure current system won’t be good enough. I do have an external GPS antenna. I also have an old SimRad auto pilot, never used it. I have noticed the system seems to run throughout boat, Have some units down below and not sure what they are. I am into computers but not sure of this system.
I am going to continue to research and speak to my mechanic at my marina.
- MakinTime
Even though we boat the river it is nice to track your routes and such.
