RIB/Tender Retrieval/Storage System
- petergbolton
- Vessel Info: 2005 Carver 444 Aft Cockpit
- Has thanked: 8 times
- Has thanked: 598 times
- Been thanked: 1281 times
Re: RIB/Tender Retrieval/Storage System
- Hugo
- Has thanked: 2 times
- Been thanked: 23 times
When I talked to Carver they said keep it under 600 pounds. You'll probably also have to remove the storage box on there if yours has one.
I know the boat well if you have any questions.
Good luck with it!
- petergbolton
Interestingly, I called Carver regarding weight. They said to keep it under 800 lbs!! hoping to keep the weight of the rib, engine and retrieval system to under 500 lbs. I don't have the storage box, so that's not an issue. We are planning the Loop next year so unlikely to go above 7-8 kts.
- Has thanked: 78 times
- Been thanked: 1093 times
A friend of mine has a 356. He originally had a Weaver Davit system, but didn't like taking the 6HP motor off all the time. He upgraded to a 9.8 and larger dingy and taking the motor off was no longer an option. He took off the swim platform box to give him some extra room (which you don't have to do) and had a shop make something like the Hurley pull-on davit system so he didn't have to remove the motor like you do if you use something like the Weaver davits.
It would usually take two people to get the dingy mounted, because you have to essentially lift about 200lbs to get it situated. I rigged a simple pulley system with some parts I had laying around for him to test and then he could do it easily himself. We configured a similar system for him and he's been using it ever since. He's even done it out on the lake in some rather rough conditions and he's pretty comfortable with it.
- AndiamoSeattle
- Vessel Info: 2006, Carver 4137 CMY, Originally commissioned in 2008, it has spent its last 10 years in the Puget Sound, WA. She features the Volvo-Penta D6, 310 diesel motors (485hr.), 3 zone AC/ Heat pumps, fresh water wash down in bow, bow and stern thruster, 8.0KW Kohler generator, 2/ 30amp shore power input from either mid-ship or stern plugins. Bridge refrigerator ice maker, electric galley featuring an electric oven.
- Has thanked: 50 times
- Been thanked: 2 times
JJ.
- petergbolton
...........hope you mean 40 degrees!!
- Seaquestered
- Vessel Info: 2001 Voyager 530 2 X Volvo 480hp
I just bought her July 2014 in New England and will be taking her to Florida to be shipped to the west coast - Location: Marina del Rey, CA
- Has thanked: 12 times
2001 Voyager 530
Volvo TAMD74 480hp ea
Marina del Rey, CA
- nautohm
- Vessel Info: Naut Ohm
1996 455 Cockpit Motor Yacht
Twin Cummins 6CTA 8.3 w/ ZF 301 transmissions - Location: Poughkeepsie, NY
I am new to a 1996 455. There appears to be part of a davit mount integrated with the swim platform support. The broker said it is "stock" on the 455, but I can't trust anything the broker said. I put some pictures in my Mechanical Stuff photo album to show you what it looks like:
gallery/album/87
I'm thinking cradles mounted to a stainless or aluminum mount that either slides inside or outside the existing mount with a pin to hold it in place. The dinghy would be entirely behind the platform (I do not want to sacrifice my platform space or add trip hazards). I'm looking at 300 lbs for a 10-12' RIB or all composite with a 15hp that I can leave on. The motor should be around 100-110 lbs and the dinghy around 120-180 lbs, and another 30 lbs for gas can and life jacket seat bag.
Something like this with a modified mount...
http://www.dinghydavits.com/images/assemblyextended.jpg
Happy and safe boating!
Naut Ohm
(Scott)
Users browsing this forum: Google Adsense [Bot] and 6 guests
