Lazy Mans Auto City Water Tank Fill Modification
- Been thanked: 1180 times
Using a solenoid, a float switch, a momentary push button activation switch and a timer it is pretty much failsafe. Install a small float switch like this in the top of the tank. https://www.ebay.com/itm/Hot-Sale-White ... %7Ciid%3A1 This will automatically shut the solenoid valve https://www.ebay.com/itm/1-2-NPT-12V-DC ... 2749.l2649 off when the tank gets almost full. Add a timer into the same circuit as the float switch/solenoid and set to appropriate time interval (15 minutes?) https://www.ebay.com/itm/DC12V-24V-LED- ... %7Ciid%3A1 this cuts off the supply if the float switch fails. Install a momentary push button switch which activates the solenoid. https://www.ebay.com/itm/16mm-Anti-Vand ... SwZVlXqas3
How it works. When connected to city water and you want to fill your tank. Push the momentary button you installed which activates the timer which is connected to turn on the solenoid until the float switch cuts the circuit off and shuts off the water supply filling the tank. If the float fails for whatever reason (highly unlikely as I have these same floats in several aquariums that have been running for many years without failure) the timer will run out and shut off the solenoid after the predetermined max run time you set it to.
Possible vent issue which could cause tank expansion. Add a vent or simply open the fill port for air expansion when in use. Technically the vent is 5/8" and the water feed line is only 1/2" so there should not be a problem however we all know vents will plug with time so an additional vent or tee off from the existing vent would not be a bad idea if not using the opening fill port for air displacement.
Oh boy, another project but hey, this is part of boating fun for me. Love this stuff.
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Lazy Mans Auto City Water Tank Fill Modification
https://photos.smugmug.com/Midnight-Sun ... 4320-L.jpg
Midnightsun wrote:Source of the post.... Biggest issue I find as we get older is we tend to forget more and more......
True dat. Look on the bright side, some things are worth forgetting......wait a minute, I guess I'd rather forget with a case of beer than getting old though
What were we just talking about?
Had an easy access hole on top of the tank or at least it seemed so. Opened the large cap to find it was not pierced yet. A hole saw took care of that in no time.
A small 3/8" hole, a dab of 4200 and float switch is now in place.
Just need my solenoid and fittings to complete the install.
- jcoll
- Has thanked: 18 times
- Been thanked: 18 times
I updated the photo above to show the relay installed and a picture of the fuse holder.
Power can come from any available always powered location as max draw is 700ma and will only happen when activated for a max of around 10 minutes assuming the tank is completely empty. The led digital display is always on however the draw is probably in the single digit ma range. I happen to have a conveniently located + and - busbar that I will be tapping into along with an in-line spade fuse holder and 5A fuse. Will post pictures as things progress.
