Oil filter
- Killin time
- Vessel Info: 1996 355 Aft Cabin
- Has thanked: 20 times
Oil filter
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Oil filter
- Has thanked: 469 times
- Been thanked: 1765 times
Re: Oil filter
Killin time wrote:Source of the post Can someone provide the number for an oil filter for a 355 with 454s? It currently has OE and because they are remote I can't just specify the year and make at the parts store.
Crusader, Mercruiser, Volvo?
If they're Mercs, 35-866340K01 or 35-866340Q03 (Quicksilver brand)
- mjk1040
- Been thanked: 246 times
Re: Oil filter
- Killin time
Re: Oil filter
- mjk1040
Re: Oil filter
- Killin time
Re: Oil filter
Re: Oil filter
Re: Oil filter
Viper wrote:Source of the post FYI, if the 51515 is a longer filter than the Mercs I mentioned above, unless you know you already have a long filter you should check the clearance you have below the housing if it mounts right side up. Depends on your application and where it's mounted but some applications don't have the room for the longer filter.
Totally agree....that is why I suggested getting the number from the filter on there as there is no way of us knowing what application there is, ....I know with mine ( right side up ) there is limited room ( longer is not a kind fit ) as Viper suggests.
Imo , I would not worry too much about the filter size anyway , they aren't on long enough ( see what I did there ) and not in any sort of dusty/dirty environment...the short ones will be just fine IMO.....
- Killin time
Re: Oil filter
