1976 Carver Mariner 3396
Gmnellis
Vessel Info: 1976 Carver Mariner 3395
Postby Gmnellis » May 13th, 2018, 11:37 am
Just purchased a 1976 Carver Mariner 3396. Gutted the inside and in the process of getting new flooring, curtains etc. Mechanical issues that I’m aware of...one engine stuck in forward and water heater needs replaced. Water heater is in engine compartment and not sure how to get it out without pulling engine. Anyone have experience or advice?
Re: 1976 Carver Mariner 3396
Postby mjk1040 » May 13th, 2018, 7:21 pm
If water heater is not leaking replace the parts. Or maybe take it out piece by piece?
Been thanked: 491 times
Postby waybomb » May 13th, 2018, 8:24 pm
Welcome aboard!
What's directly above it?
Nothing wrong with making a new access panel.
Postby Viper » May 13th, 2018, 10:06 pm
Welcome aboard.
Looks like the WH is at the transom under the storage area. There may be an opportunity to gain or create access from/through there if that space is wide/deep enough but from the pic, it looks like the unit is right up against the transom so it sits right under the front wall of the transom above deck. How much room is there between the port engine and the side hull?
Why does it need to be replaced? Can it not be repaired? If it can't come out without removing an engine, is there a space elsewhere in the boat to install a new one and simply leave that one there or cut it up and remove it in pieces as Mike suggests. If you dismantle and remove the cover and fittings, the actual tank itself might come out on its side if you have room to tilt it under that support on top. Hard to tell how much room there is between it and the engine or bell housing. It won't be an easy one!
Postby RGrew176 » May 13th, 2018, 11:28 pm
Welcome Aboard. Good luck getting everything up to a good working order. Hope you get it all fixed and start having lots of fun aboard.
MistyRiver
Vessel Info: 1976 Carver Santa Cruz 2866
Ford 351 Single Engine Inboard
Been thanked: 2 times
Postby MistyRiver » May 14th, 2018, 8:11 am
I have a Santa Cruz 2866, with the Water Heater in the same place. I found it easier to remove the hatches, some deck hardware (ladder fasteners, etc) and just lift the deck. As heavy as it is (Mine is 8'X8'), it's easer than removing the engine. It also gave me access to some more hard-to-reach areas for some well needed maintenance.
KandJ72
Vessel Info: '76 Carver Mariner 3395
Twin 351W Vdrives
Refit in process
Has thanked: 20 times
Been thanked: 3 times
Postby KandJ72 » November 17th, 2020, 2:16 pm
Just wondering how you made out with your project. We have the same year/model. Our water heater is actually mounted between the 2 engines. Still would be a pain to get out though. What kind of fuel consumption are you getting at cruise speed?
Been thanked: 413 times
Postby Cooler » November 17th, 2020, 4:22 pm
KandJ - you may want to email the author with your request. The post was from May of 2018 originally. Also, the standard generator brand at that time was Westerbeke, but other brands were used in a pinch. 8-) er
Users browsing this forum: No registered users and 45 guests
