Anode Replacement
Re: Anode Replacement
Determine it is zinc, aluminum or magnesium. If its zinc you may want to replace it with the others as they should all be the same.
I am in mostly fresh water but often travel into brackish water. I use aluminum anodes.
ZC-406M, You need 1 of these. http://www.boatzincs.com/ZC-406M.html
No bother price shopping as I already did it for you.
Carver does not bother to ask where the boat is going to be used, they just deliver all of them with zinc however going to magnesium for fresh water is the correct route for the best protection.
- Has thanked: 603 times
- Been thanked: 1311 times
I only use aluminum in fresh water inboard applications now. Ya magnesium is more active and is great for aluminum sterndrives but considering the running gear on inboard applications is stainless and bronze, aluminum is active enough for those metals, will last longer than magnesium, and is less expensive.
That being said, the cost difference for the entire set is only $30 between alu and mag and as far as boat dollars go that is nothing. Magnesium will deteriorate faster however there is no denying it does provide the ultimate protection for boats in fresh. I cannot comment on the longevity since I just bolted those Magnesium units on last week!Then again Carver put useless zinc on my fresh water boat which have been in place for 10 years and there are no signs of corrosion that I can see. Maybe I was lucky to not be in a hot marina/environment or maybe the Charles isolation transformer Carver used just works very well or maybe a combo of both. As Viper said, running gear is stainless and bronze unlike problematic outdrives that are very prone to this problem. As a matter of fact, I cannot recall reading about corrosion issues on inboard boats like we have here.
My boat was the same, had zinc on it , looked like brand new ,on the first year I changed to the correct anodes you could see evidence of activity.....now the trick here is to get all your dockmates on the bandwagon so you are not protecting everyone else.
Edit...to add...there is no possible way to explain this fully in just a few short sentences, but the overall idea is here. That said, suffice it to say ,just protect your boat with the correct anodes for the areas that you boat in and in most cases all should be well.
Pricing between the zinc and aluminum was about $2 cheaper for the entire set for the zinc compared to aluminum and like I said about $30 more for the Mag over the Alu. All in all it is not very expensive and very easy to change out when on the hard. Even rather easy to do with a mask and a deep breath while in the water if push comes to shove.
) so yes I used both sets in the end. You could use 1 set and split like you said but then again it would just need replacement sooner as there is less material. They come bolted together with nut and bolt so nothing extra to buy. Same thread as your existing one so just reuse the screw if you want to split like the original. Either way works, your call.Return to “General Repairs & Maintenance”
Users browsing this forum: Google Adsense [Bot] and 28 guests
