Plumbing, Alternative 15mm Quick Disconnect Fittings
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Plumbing, Alternative 15mm Quick Disconnect Fittings
Not 100% sure but think it is Sea Tech. I have purchased these in the past for my Carver and they look identical. I do know Defender carries them. http://www.seatechinc.com/Products/Metr ... and_Tubing
bud37 wrote:Source of the post.....do you know who is the original maker of the quick disconnect oem fittings on our boats......
They'll be either SeaTech or Whale. Both have 15mm and 1/2" fittings as well as adapters to go from one size to the other.
bud37 wrote:Source of the post .....I have a couple at the water tank that are connected and disconnected a lot and are beginning to be a problem......
Sometimes it's not the fittings but the line itself. Every time you connect and disconnect it abrades the line in the area that gets inserted into the fitting, take a close look. If that's the cause, cutting 3/4" off the end solves the problem. If it still leaks after that, then replace the fitting.
Are the lines red and blue?
Viper wrote:Source of the post Are the lines red and blue?
Yes they are........I have been clipping them already, they are getting too short..
....and I just get the impression the fittings are getting to the end of life as well.....hopefully when I check today the drip will have stopped for this year..
Sorry for the hijack Hans...
