2005 38SS VP 8.1 transmission clunk
BlueAyes
Postby BlueAyes » May 30th, 2018, 12:39 pm
Starboard trans clunks into gear forward and reverse. Trans is quiet when running. Thoughts?
Been thanked: 1310 times
Re: 2005 38SS VP 8.1 transmission clunk
Postby bud37 » May 30th, 2018, 12:49 pm
Welcome.....do you have trans/ V drives attached directly to the engines...??
If so I believe that is the side with the chain drive.
Postby Viper » May 30th, 2018, 10:37 pm
Welcome aboard. Exact model of engine and transmission would help. I assume "VP" refers to Volvo Penta. Can you provide serial numbers?
What rpm is the engine running at at idle before putting her in gear? Have you checked the fluid level and condition of the fluid?
