Can my hull repair wait until fall or must I do it now?
- lakeman
- Vessel Info: 1977 Carver Mariner 2896
I went for a swim and I could clearly see and feel the damage. The damaged area is about 2 feet long. It was hard to tell but I would say the depth of the damage is somewhere between 3/32 inch (3mm) and 3/16 inch (5mm) at the deepest point.
Since I have no trailer, it is going to cost me $800 to get the boat out of the water and back in, so I'd love to just continue using the boat and deal with the gash in the fall. However, I want to be smart about it. Do I need to deal with this ASAP?
There's no water leaking in. I sleep on the boat at night, so I'm monitoring closely.
Re: Can my hull repair wait until fall or must I do it now?
If it is into the core you want to pull it asap, as the water will continue to soak through the core throughout the boat and will not be worth repairing.
As far as worring about sinking while you are asleep, if you just grazed the hull, I wouldnt lose much sleep worring about it.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
The outer layer is gel coat, do you see any bare fiberglass? If you do, haul her out now.
- Been thanked: 1113 times
- Has thanked: 603 times
- Been thanked: 1311 times
- lakeman
Given that it has been 2.5 days since the incident, if I pull the boat out, would you recommend that I left it dry for a number of days before repairing in case the wood core has soaked up some water?
Users browsing this forum: Google Adsense [Bot] and 26 guests
