355 Aft cockpit gate
- Jlubas
- Vessel Info: 1995 Carver 355 Aft Cabin
I have seen newer or 40ft versions of my boat with what appears to be a white gate for that area. Anyone have an idea where I might be able to find one? Or has anyone come up with an alternative solution that worked well.
Thank you in advance for any ideas, suggestions or feedback.
This is kind of what I am looking for:
Crusader 454 XLI's
- Been thanked: 654 times
Re: 355 Aft cockpit gate
- Jlubas
Crusader 454 XLI's
- cpoint
- Has thanked: 208 times
- Been thanked: 32 times
- mjk1040
- Been thanked: 248 times
I agree. I've seen canvas and sliding panels used. I saw one sliding panel that had a King Starboard track installed on the deck that the panel slid on. In the closed position, it latched to the vertical SS rail so it was pretty secure. When opened, the panel would disappear behind a custom made bench and backrest across the back of the deck. Worked really well but I wonder how much of a tripping hazard that was. The track was pretty low profile but I don't know if I'd want anything protruding on the deck right at an opening. Best working/looking sliding option that I've seen though.g36 wrote:Source of the post The versions with the door ithink at year 1998 have solid fiberglass walls and not the acrylic panels. It would not be wise to mount anything to the acrylic panels do to strength issues and if they break your pretty screwed on getting a match. On my 97 405 which has the same acrylic panels I made a sunbrella piece that covers the door area and can be snapped open or closed. I also have thought about a plastic that could be slid sideways from the inside to make a door but sunbrella is easier and fine for my needs. Maybe someone else has a idea too.
- cpoint
mjk1040 wrote:Source of the post Sweet idea Cpoint. I have a canvas guy that could make them for me! Are they adjustable or ridged? Appear 2be ridged.
Stainless steel. not adjustable. both sides were off by 1/4 inch. had to measure several times. but they can easily be opened and closed, also feels safer when going by there now.
- mjk1040
- cpoint
mjk1040 wrote:Source of the post Cpoint; do you have to completely remove to use that boarding area or can you pull one end and let it drop without hitting the deck?
No, only one side is removed and it will swing up or down. I will put more detail pictures, what I did next time I go. I used the part where life line was hooked up to. Thats why it was difficult finding the end cap with double prongs (not sure what is called), since there was single eye as part of the existing where life line gate hooked up to.
