3607 lower station fuse door
- Been thanked: 1113 times
So I'm installing a fuse panel to split up the loads and also get rid of the push-on connectors, as they get unreliable with even slight corrosion. I bought an identical panel to put up on the bridge as well (and that is wired similarly)
For access to it, I decided to cut the panel and put in a sliding door so you have easy access to the fuses. I'm not done with the wiring part yet, but have moved over a couple circuits to clean up some of the wiring.
I carefully cut out the door from the panel. When I trimmed out the opening, I could still use the peice I cut out so the grain matches exactly when the door is closed.
Here's a couple pics:
- Has thanked: 603 times
- Been thanked: 1311 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: 3607 lower station fuse door
