New member and just got a mariner 360 2004
Topic author Israel
DrSleep
Vessel Info: 2004 Mariner 360
Postby DrSleep » July 23rd, 2018, 10:19 pm
Looks like I will have a lot of questions
1. When the boat is on shore Power the AC’s are working BUT when of shore and generator works I can’t turn them on. Any help? Thanks
Has thanked: 469 times
Been thanked: 1765 times
Re: New member and just got a mariner 360 2004
Postby Viper » July 24th, 2018, 6:34 am
Congratulations on your new acquisition, and welcome aboard. I'm sure other Mariner owners will chime in but I suspect the switching relay for the AC line (line 2) has failed. There are relays typically behind the electrical panel that automatically switch the source power from shore to generator when you turn the generator on. You can usually hear them when they activate. I'm assuming that everything else works and that you have two shore power lines?
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » July 24th, 2018, 7:18 am
Welcome to the forum.....on the top back of the generator should be a black box, on the side is a breaker switch, some fuses and the a start toggle, make sure the breaker is in the on position to get power to the boat from the gen. The gen can be started and stopped from there and run without sending power to the boat.
Has thanked: 64 times
Been thanked: 481 times
Postby waybomb » July 24th, 2018, 6:08 pm
Welcome aboard!
