shower sump quality
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
shower sump quality
ps. I only have one shower that empties into this sump.
- Been thanked: 601 times
Re: shower sump quality
- Been thanked: 1180 times
Using a similar pump design that a vacuflush uses, a whale pump will never have these issues. It,s a diphram pump with duckbills. Easy to service/rebuild and can pump big pieces without issue. They use a sensor as opposed to a float which is also more reliable. When you look at it all it is is a box, a pump and a float/sensor. Not all that cheap but you do get piece of mind and dependavility. https://www.defender.com/product.jsp?na ... id=4318492
Just what I heard. Not personal experience.
tomschauer wrote:Source of the post I would think the "stink" would come from the reservoir, not the pump. But if it doesn't have a screen to hold the hair etc. maybe consistent hot water flushes would prevent the smell?
I agree, the reservoir is where any smell will come from. The diaphram pump will suck up the hair and all and pump it overboard, not so on any impeller type pump. Cleaning the reservoir should be a snap since there is nothing in there as the float/sensor is part of the cap. Open the top cap and dump fresh water in until clean. So far the system does seem superior to anything else. Looking at buying the reservoir/sensor at defender https://www.defender.com/product.jsp?pa ... id=4410618
The gulper 220 pump on Amazon for a total savings of about $100. https://www.amazon.com/Whale-Marine-BP1552-Gulper-220/dp/B000FHQL5G/ref=sr_1_1?ie=UTF8&qid=1532567884&sr=8-1&keywords=gulper+220
Same reservoir, same pump, should bolt right on to the brass threaded inserts.
Here is a PDF of the reservoir specs. https://www.whalepumps.com/marine/siteFiles/resources/docs/resource-library/datasheets/cmcc_pshaw_Grey_Waste_Tank_EU_v2_0118.PDF
- amanphoto
A new unit, a spare pump and float on board should cover all bases.
Users browsing this forum: No registered users and 7 guests
