1987 Carver 3207 Cruising speed not as per specs
- flo2
- Vessel Info: 1987 Carver 3207
- Has thanked: 1 time
This year I cannot reach above 15Kn at 3000 RPM
I have Mercruiser 5.7L and both engines behave the same, if I push the throttle above 3000, the RPM starts going down.
Someone told me it could be the wrong pitch on propellers.
I did a survey at the beginning of the season and it shows I have propellers 18 x 18 as er the specs. Not sure if the inspector took the value in the specs or an actual reading on propeller.
Any info or comments on the above would be appreciated.
Mike
- Been thanked: 1180 times
Re: 1987 Carver 3207 Cruising speed not as per specs
- waybomb
- CYO Moderator
- Has thanked: 64 times
- Been thanked: 481 times
Spark plugs/wires/cap/rotor how old?
Check total timing, not just base timing. Base timing is at idle, total timing would be at whatever rpm your spark controller stops advancing.
None of this is very expensive, and would rule out the basics.
- Been thanked: 646 times
- Has thanked: 78 times
- Been thanked: 1093 times
Is the bottom clean?
I also think that filters or timing advance are your best avenues for troubleshooting.
- Has thanked: 598 times
- Been thanked: 1281 times
- flo2
When I purchased the boat, previous owner had the engines redone and at the time of the transaction engines had 70 hours.(apparently)
I did about 130 hours since.
I know for a fact that water tanks were empty and fuel tanks were at less than half at the sea trial so this might be the difference between the 17kn and 15 kn.
The bottom is clean, navigating in fresh water (Lake Champlain) which I would categorize as clear water.
As for the RPM dropping at 3000rpm, it is happening on both engines so perhaps the mechanics who did the adjustments possibly did both of them wrong.
Last weekend was quite rocking and I lost an engine so I replaced an inline fuel filter and a fuel/water separator but I am not aware of an anti-siphon valve, will have to look this up. Anyways, after replacing both filters, engine ran fine but still have the 3000 rpm limit.
Mike
- waybomb
- CYO Moderator
- flo2
I know it's been a while since my first post but I wanted to come back and inform on the issue I was having so it turns out it was a bad coil.
Why both engines had the same limit, I presume the one with the bad coil had the limitation and the other engine could not exceed that limit by itself.
I was told, I had an automotive coil and not a marine coil... looks like one is oil filed and the other is air filed and I don't see why it would make a difference but after replacing the coil, I can now bring it up to 25Kn
Life is good.
Cheers!
