Tips or tricks to getting sediment out of the gas tank...
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
The supply line failed, and gelled shut. The return line was always open and looked good, but it had a small amount of the gel like substance (the substance you get when separated ethanol reacts with rubber fuel line) in the hose. I'm wondering if my return line failed and is deteriorating, thereby introducing sediment back into the tank, and causing my issue. I'm going to replace both return lines this week. They're about $40 each, it's a fairly cheap investment.
This is maddening. I've drained my starboard tank twice, and my port tank once. Still bad gas. The gas is now clean, smells right, and its useable when I drain it, but has a lot of sediment clogging material, only when its ran through the boat. Ran out of the boat it looks great and I dump it right into my truck.
I've also considered hooking a pump up to the motor, and running a continuous loop from the supply line, to the pump, to a filter, to the return line, and letting the gas cycle through a filter for 20-30 min. intervals.
The other option is to nix the Oberg fuel filter, and replace it with a can style filter that can hold more sediment.
I never thought that getting bad gas out of the tanks would be the single hardest part about getting this boat right. Everything else runs well. (Aside from erratic idle on the port motor, but I can't diagnose that, until I'm sure that the gas is right.)
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Tips or tricks to getting sediment out of the gas tank...
Just something I came across while reading about fuels, sounds like it might be reasonable given the problems boaters are having after switching.
I think if one really wanted to clean a tank and be done with it, you would have to hire a service that can vac it out and wash the tank etc...good luck man.
- 390Express
- Captain
I replaced the fuel return line on the starboard motor, hooked up a pretty large 12v, 10gph pump, hooked a can style fuel filter/ water separator to the pump, and connected the pump and filter to the system in the same manner as the factory pump and filter. I ran the system for 30 min like that, just cycling the gas that was in the tank. I went to the gas station, picked up another 10 gals of fuel, and ran the pump again for 30 min, while I was adding the new 10 gals to further agitate and stir up the gas in the tank... knock on wood, seems like I'm good to go.
Boat ran for an hour on the main tank. It's the longest its ever ran on the main tank, and has restarted twice since running for an hour, with no issues. I plan on taking it out this weekend. We'll see... I'll keep you updated.
- 390Express
- Captain
I've been cautioned on here about running two filters, and did not want to do it for a number of reasons, but read that it is perhaps necessary on the WIX page, whom seemed to provide an endorsement of the same. I know - Wix sells filters, they'll tell you anything, right? Well, they could say to eliminate your old system and install theirs, but the actually recommend adding a 2nd filter. After adding the 2nd filter I can now run my boat for about an hour and half. It's the size of the filter vs the Oberg that makes the biggest difference, and I love that the can style is trapping more water than my prior filter. (water was getting past my prior Oberg filter, and causing me RPM issues) Motor used to hesitate and sputter around 3000 RPM. I believe that was caused by the small amount of water in the gas. Now it rpms to 4000k no problem, and I'm confident that it will hit 4,500 if I ask it to. Ran the motor for about 5 hours last night. I had to drain the fuel filters of water twice, but was able to recycle them more or less (turn them upside down, and drain out the water and gas, and use them again). I plan on keeping 4 of them on the boat for when I'm out on the lake, but it's running for over an hour with its current setup. The extra filters are more precaution than anything.
If you don't have a can style, I would recommend adding one asap. Pics to follow. The system that I installed required no bolts, no modification, and can easily be switched back to the factory configuration in 10-15 miuntes. After running 40-50 gallons through it, I think I'll try going back to the Oberg alone. We'll see.
- mjk1040
- Been thanked: 248 times
mjk1040 wrote:Source of the post My Friend 2 items I would like to make you aware of! The Fram Filter using is an oil filter, not a fuel filter I do believe and I would suggest not using Fram Oil filters on your engines if you have seen any of the oil filter comparisons on You Tube, etc.
PH8A is for oil! Ditto on the Frams.
- 390Express
- Captain
The Fram extra guard can be used for fuel or oil, and is marketed as such. I'm using it more as a large sediment filter, with another filter behind it. There's no way for the quality of filter to hurt my motor(s). They're working great and doing exactly what I want them to do. The only thing I'm considering is buying a sierra fuel filter/water separator with a drain on the bottom, but I'm having trouble finding said filter with a 3/4 thread.
- 390Express
- Captain
I talked to the mechanic at my marina, and he said that they would have pulled the fuel sender, and drained the tank(s) completely. I wish I would have done that from the beginning, but at at this point I'm pretty close to being good. It's fairly simple to get to the starboard fuel tank sending unit (I can access it from the aft cabin, I wanted to avoid running a hose through the aft cabin to get the fuel out), but I think the port sending unit is beneath the fridge in the cockpit area. That fridge has been acting up (cabin fridge is fine), so it may be a good idea to pull it anyhow, but it seems like a huge headache.
Both motors start and run for hours at this point, even with a small amount of water in the tank(s). The starboard motor will operate under a load, and drives fine, the port motor will not currently maintain a steady RPM or operate under a load, but it's getting close. Both motors will run for over an hour with a BS Fram PH8A filter. I can drain the PH8A and re-use them, it's water that is giving me the brunt of my problems.
Should I
1) start over (again) and drain the tanks (again)?
2) Run the boat for 10-12 hours until the tanks are near empty (as empty as they can be with the pickup tubes); or
3) Add a ton of good gas (approximately 100 gallons per side), to further disburse the small amount of water in the tanks.
390Express wrote:....The Fram extra guard can be used for fuel or oil, and is marketed as such.......
Yes but is it specifically designed to separate water? That is a must in a marine application.
390Express wrote:Source of the post......There's no way for the quality of filter to hurt my motor(s)......
You may want to re-evaluate that statement. I'd say a sudden loss of oil pressure at high rpm due to a failed oil filter would be enough to harm your engine if not caught in time. Had it happen three times. In each case, the fault was the filter. Of every brand I've used, the only oil filters I've had fail were Frams. Giving them 3 chances over a two year period was enough for me to not recommend them anymore. That's a pretty high failure rate considering they weren't the main brand I was using at the time. Maybe they've changed but there's no way I want to risk anything I work on or own until the general concensus convinces me otherwise. For now, that's not the case, but don't take our word for it, there are many wright-ups on the internet of similar experiences.
