Port Engine Continues To Run Even With Key Removed...
- mbjezior
- Vessel Info: Carver 370 Aft Cabin
Thought it was a bad ignition switch- replaced it- tested it- worked normally. Then when back at dock omce again it failed to shut down.
I’ve been reading a ton and maybe an alternator diode? Have an alternator on order..
Could be the wiring harness maybe?
Has anyone had this issue?
1994 Carver 370 Aft Cabin
Crusader 454XL w Holley Fuel Injectors
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Port Engine Continues To Run Even With Key Removed...
- Been thanked: 1111 times
I did this inadvertently to a truck once. Wired an LED into the ignition so it would light when the key was OFF and go OFF when the key was ON. Worked great, except there was a trickle of current going through when the IGN was on, so if the vehicle was started, it would not shut off. A bad ground between two accessories can do the same thing.
Good luck in your findings and report back with the solution to the issue.
- mbjezior
- mbjezior
I did replace the ignition relay on the port side- will run it wednesday for a period of time and will report back...
Users browsing this forum: Google Adsense [Bot] and 26 guests
