AC Unit fault
Tomion
Topic author - Deck Hand
- Vessel Info: Carver 530
- Has thanked: 1 time
- Been thanked: 2 times
AC Unit fault
My Marine Air AC is doing some weird things. An AC repair guy replace the control unit and it seemed to work ok for a week or so. When I select it on it shows correct cabin temp and the AC unit cones on and starts cooling, then after a minute or so the indictated cabin temp starts fluctuating to lower numbers like 80 then 76, 73, 67. I selected 65 degrees to keep the unit runing as the indicated temp fluctuates up and down but eventually I get a HPF fault.
I swapped the the control unit with my aft AC but get the same fault. I presume it is a problem with the AC computer but afraid to bring AC guy out again without some input as when I tell him what it is doing and provided a video of it he seemed perplexed.
- Been thanked: 601 times
Re: AC Unit fault
The "moving temp display could be an issue with the controller on the wall or the control board at the a/c unit.
Tomion
Re: AC Unit fault
Re: AC Unit fault
If you have decent access, it is not difficult to replace the control board. Make sure power is off to both units and the pump, as the pump power goes through relays of both units.
- Been thanked: 646 times
Re: AC Unit fault
Re: AC Unit fault
Tomion
Re: AC Unit fault
- waybomb
- CYO Moderator
- Has thanked: 64 times
- Been thanked: 481 times
Re: AC Unit fault
Do you have a cooking thermometer you can stick in the supply outlet? How cold is it?
Can you gain access to see the evaporator coil? Is it shiny clean?
- Has thanked: 598 times
- Been thanked: 1281 times
Re: AC Unit fault
Re: AC Unit fault
It kind of sounds like it tries to go into a calibration mode. I would check the plug in connection in the back of the wall unit and at the a/c unit itself to make sure it isn't that simple.
If the other unit is the same brand and vintage you could try swapping the control boards and see if the problem moves to the other unit.
