Tank Watch 4 Lights Not Working
Been thanked: 1180 times
Postby Midnightsun » September 10th, 2018, 7:31 pm
Well at least 2 of them are not. The empty and full lights work which leaves the non working Low and Mid lights non functional. Was like this when I purchased the boat and assumed the sender was at fault. Oddly enough the front unit is almost the same except the Mid light does work along with empty and full. Pulled the sender and cleaned them, no change. Ordered new sender and installed, no change! :banghead: Will break out the volt meter and do some testing like I should have done first time around. Just wondering if others have had this issue. I am thinking the low and mid lights are the one that technically should be lit most of the time so maybe the LED's are toast? Are they led bulbs?
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 487 times
Been thanked: 206 times
Re: Tank Watch 4 Lights Not Working
Postby pepmyster » September 10th, 2018, 9:40 pm
On ours, the low and mid are usually lit also. I've seen the empty light and the full light work also.
Been thanked: 601 times
Postby tomschauer » September 10th, 2018, 9:57 pm
you can buy the bulbs alone. They are not led, so its a good chance they have failed.
Has thanked: 598 times
Been thanked: 1281 times
Postby bud37 » September 11th, 2018, 7:31 am
tomschauer wrote:Source of the post you can buy the bulbs alone. They are not led, so its a good chance they have failed.
Tom, do you know where we could find those small bulbs, and maybe the tiny ones from the shore power indicators that can only be seen in the dark......thanks...
Postby Midnightsun » September 11th, 2018, 8:58 am
Not sure those bulbs are replaceable unless you do some soldering. Nothing mentioned on the parts list either. This is the only picture I could find of what the lights look like, Sure do resemble LED.
Postby tomschauer » September 11th, 2018, 9:35 am
Mine are Tank Watch III and have replaceable bulbs. The 4 looks sealed.
I may have provided bad info. Sorry.
Postby Midnightsun » September 11th, 2018, 10:11 am
tomschauer wrote:Source of the post Mine are Tank Watch III and have replaceable bulbs. The 4 looks sealed.
Actually that is good info to know for the who have the tank watch 3 unit. ;-)
