1998 350 Mariner Mercruise 350 Magnum 2800 RPM WOT issue
- grizer
- Vessel Info: 1998 Carver 350 Mariner
1998 350 Mariner 5.0 Merc 3000RPM WOT
Re: 1998 350 Mariner 5.0 Merc 3000RPM WOT
- Has thanked: 602 times
- Been thanked: 1311 times
- grizer
grizer wrote:Source of the post Thank you both of you, however no hints in either of those replies. If anyone else has more suggestions I could really use the insight.
A couple questions that may help,....to be clear you are saying both engines act exactly the same with fuel pressures etc.
Is this something that has just happened abruptly to both sides ( were there any alarms, codes in memory etc )?
Are these engines MPI or TBI ?
Any work been done lately in the engine compartment ?
Have you changed fuel source lately ?
Thats all I can think of , but this may help the guys a bit.....good luck man..
Hint, its either a restriction in the fuel supply to the pumps or the pumps / regulators themselves.
Good luck.
- grizer
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
While the low fuel pressure is definitely worth looking at, is there any chance the boat is way overpropped?
This is important info the guys need to help you........
Users browsing this forum: No registered users and 47 guests
