2357 montego with 5.7
senjen
Vessel Info: 1990 2357 Montego.
1986 28 Monte Carlo
1986 21' scarab 1
1980 30' Sedan Bridge
Has thanked: 3 times
Postby senjen » September 26th, 2018, 10:26 am
anyone know what the normal running temp would be? boat is lake water cooled.
Re: 2357 montego with 5.7
Postby km1125 » September 26th, 2018, 10:57 am
Typically would be 140 or 143F. In freshwater, you could run a little higher but in saltwater the salt will come out of solution over that and cake everything up. You have a similar problem with the minerals in freshwater, but not quite as bad.
Postby Viper » September 26th, 2018, 10:27 pm
I prefer running 160* in a fresh water lake for a raw water cooled system. Unless a previous owner made a change, it's likely you're running a 140* stat as KM mentioned.
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Postby vineyardgray » September 26th, 2018, 10:52 pm
Both of the 'stats on my boat appear to hold at 160* unless pushed hard. I can sustain 15 knots or so before one of the engines overheats. She's a 3867 Santego.
:beergood:
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
