1984 3207 Aft Bilge location?
- bmalmquist
- Vessel Info: 1995 Carver 370 Aft Cabin
- Has thanked: 1 time
Thanks in advance!
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 1984 3207 Aft Bilge location?
You have to open every obvious opening, look under steps, pull out drawers, raise berth mattresses and often the board the mattress sits on. On our old 3807, the forward berth had a board under the mattress and once you got into that space, the bottom of the space had another board that could be pulled up exposing another storage area.
A good chance you will have to pull up carpeting to access other openings as well.
When you start your search, have a good flashlight and figure out the purpose of every hose you see, find all thru hulls and determine what they are for.
On my 356, I have a built in night stand next to the aft berth. You have to remove the drawer to access the aft bilge pump and the only time it turns on is when you start to speed the boat up and any water in the bilge rushes aft. The aft pump is mounted higher than the other two relative to the waterline.
- Jhawki1
- Vessel Info: 1986 Carver 3207 Aft Cabin. Excellent shape, kept on a lift most of it's life. Mercruisers with 300 hours, Kohler generator
- Has thanked: 5 times
- Been thanked: 5 times
