Volt meter switches on a 3807
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
We just purchased a 1988 3807 and are getting to know this boat. During the sea trials, the surveyor marked the volt meters at the upper and lower helm as INOP. In digging around, I found two independant switches for these meters to be turned on or off in the hanging closet in the aft berth. Is there any reason NOT to leave them on? They don't work unless each engine key is on. I can't figure the reason to have them switched in the closet anyway.
Thanks,
Vic
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Volt meter switches on a 3807
- Been thanked: 654 times
- VicB
G36, we are practically neighbors. Currently our boat resides in Scottsboro, which is not too far from you.
- Been thanked: 1113 times
I leave the voltmeters active. Easy to keep an eye on the batteries by just checking those switches periodically and it will tell you if there's something amiss with your charger. Eventually you will be able to tell whether the charger is feeding charge to the battery by the voltage at the meter.
