Carver 3207 Exhaust Hose
- ataylor233
- Has thanked: 83 times
- Been thanked: 7 times
- Has thanked: 603 times
- Been thanked: 1311 times
Re: Carver 3207 Exhaust Hose
- Been thanked: 1113 times
- ataylor233
bud37 wrote:Source of the post Good catch.....all the original hose info you need is usually stamped on the hose, have a look at Shields 4" ID hose with the blue stripe, either soft sided or hard, the hard has wire in it and there are a few different temp spec hoses ( thicker ).......if you remove that piece you can take it to the supplier ( marina etc ) and have them match it.....have a good holiday season.
Yeah I am glad I caught it now I will examine the hose a little closer and match it this weekend. Thanks for the advice
- ataylor233
- ataylor233
- fleck05
- Vessel Info: 1983 Carver 3607 Aft Cabin
- Has thanked: 20 times
- Been thanked: 4 times
- Contact:
- ataylor233
fleck05 wrote:Source of the post YES! You just confirmed what I've been figuring on our boat. A wet spot in the aft head has an exhaust hose going right under it. Being in the head I originally thought it was a leaky fixture, but to confirm I shut that head off from use (we have two) and haven't used it it for 2 months... still a wet spot. This is great to see. Question: Did you need to pull the boat out of the water to repair it? (It seems like a big yes on that since the exhaust is under the water line). The exhaust line on the starboard side of my boat is much newer, so it looks like they swapped that one out at one time, but didn't want to go to the expense of the second one (it probably wasn't leaking yet).
My boat is out of the water already but this is something that can be repaired in the water the exhaust is above the water its easy to route but pulling the hose from the muffler is a challenge but doable. Depending on the year of your boat the connection to the exhaust tip might be a little hard to get to. Good luck
