Battery Question
- ataylor233
- Has thanked: 83 times
- Been thanked: 7 times
Battery Question
- Been thanked: 1112 times
Re: Battery Question
Otherwise, don't see any big issues with what you're trying to do. You're just doubling the capacity on one side. If you were going REALLY big, say 4 batteries on that side, then there might be a concern about the alternator size vs the battery bank size. With just two I wound't be concerned.
- ataylor233
km1125 wrote:Source of the post You have to read the charger manual or consult the manufacturer. On some you would only use two leads, but on others you'd hook two of the leads to the same battery and one of the leads on the other battery or the charger won't function correctly (or you lose out on the total capacity of the charger).
Thank you for your input i will check out the charger info
- Has thanked: 602 times
- Been thanked: 1311 times
ataylor233 wrote:Source of the post i have a Carver 3207 I have a 2 Batteries , bank 1 and 2 on the switch ... I would like to add a Second Battery to one bank and run it in parallel so 1 will be 1 battery and switch 2 will be 2 12 volts run in parallel. running ruffly 200 amp hour my question is does anyone see any issues with this when it comes to charging with the alternators i also have a 3 bank charger i only use 2 leads ? ? ? ? ?
Sounds good, just take the power off the other end of the bank from the ground......should be just fine.
Users browsing this forum: No registered users and 7 guests
