Mid Hibernation Visit
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Midway through the hiberbnation and time to 'top off' the batteries. I purchased 2 new batteries in the beginning of 2018 season which are both ASM technology.
I purchased one new deep cycle house battery the beginning of 2017 season and will likely change out the remaining two older units (pushing 5 years) in about 80 days! They were all between 70% and 84% of capacity after about 3 months on the hard.
The reason for 5 batteries: 1 house, 1 generator, 2 x engine starter with a second unit in series with the starboard starter battery for the bow thruster. Both of those are ASM's which are good for starter/bow duty due to their ability to punch out power and recover quickly.
The fever is beginning to strike!
Re: Mid Hibernation Visit
I have a problem when it comes to topping off the batteries during the winter as the boat will not accept anything but 220v for shore power and therefor I cannot plug in to top off. My solution will be to install a separate 4 bank charger to handle all 4 banks with a recessed 110v inlet which is almost always available when on the hard. I do have a Noco 40a unit like this https://no.co/gen4 and did purchase the receptacle https://no.co/gcp1 Actually was supposed to install this before the winter but never found the time. This is just on of my once again overboard installations which will protect my rather expensive house bank as I plan on adding an additional 2x L16 trojans next year so I end up with a 870ah house bank.
- waybomb
- CYO Moderator
- Been thanked: 491 times
That's not safe. Use wood next year. Cinder blocks fail. They support the boat. The stands only steady it.
If your marina won't provide wood, make your own and keep them at your house when you are not in storage.
- Has thanked: 603 times
- Been thanked: 1311 times
waybomb wrote:Source of the post Is that cinder blocks under the keel????? Yikes!
+1
Very nice shrink job, all the way to the antifoul.....nice.....
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- mjk1040
- Been thanked: 248 times
- denpooch
MJK: tried plugging in to the boats main chargers using an adapter from their standard 3 prong outlet to the boats connection. Blows the gfi each time.
Bud: Yea I am happy with the shrink wrap job. A bit pricey ($950) but the work is good. I 'take care' of the guys doing the work and they do their best.
Waybomb: As far as cinder blocks. That's standard practice in our neck of the woods but your concern makes sense of you have had experience with that. I will measure it up and form some block of wood. Thanks for the heads up.
- denpooch
- extraextra
- Vessel Info: 1998 405, 2005 444
- Contact:
Tom
extraextra wrote:Source of the post Hi, question regarding the charging. I have a 2005 444, and tried to use the adapter/converter from 50A to 15A so that I can plug into the power are the boat yard to charge them up using the boats internal charger. No go, wouldn't work. When you connected the charger (assuming your batteries are in parallel) how did you connect it, plus & minus from the charger directly to the first battery and let the parallel do its thing?
Tom
Question....what voltage is your 50 amps cord at....?
