450 voyager prop size
- outtoc
- Vessel Info: year 2000 carver 450 voyager pilothouse
twin volvo tamd74p 480hp engines
edc controls - Location: Connecticut
i have Volvo 480 HP engines and zf 280-1 2.27:1 ratio for transmissions
can anyone who owns a 450 voyager tell me
your prop diameter and pitch plus your cruising speed
and your rpm you use for cruising speed
thanks very much
john
- rweez
- Vessel Info: 1999 450 Voyager
Re: 450 voyager prop size
I have a 2003 460 with the same power and gear ratio. I get 2670 RPM at 29.6 MPH indicated on the Raymarine tridata.
My props have been reworked by the previous owner and are 28 x 30.6 with 2.25 bore. I just found a scan report from 2011, showing 28 x 32.5, so somebody back then was trying for higher speeds. There were several gear ratios installed in these boats, so prop pitches are all over the map on these forums.
- Been thanked: 1111 times
I'd say that's moving pretty good for a 45' vessel!!
