Carver Voyager 450 8.3 Idle Speed
Sgodfrey
Vessel Info: Carver 450 Voyager
Been thanked: 9 times
Postby Sgodfrey » February 21st, 2019, 7:02 pm
Hello -
I am close to purchasing a 2000 450 with the 8.3 6CTA Engines. The previous owner is running the idle speed adjustment on setting two on the Power Commander EC-100.
I am going to get some help from a diesal guy to adjust the idle rpm (one engine is running a little faster than the other) and I was wondering whether there are target RPM settings for position 1, 2 and 3?
Thanks in advance.
I have already learned a lot from this great resource,
Steve
bluebyu
Vessel Info: 1993, 440
Re: Carver Voyager 450 8.3 Idle Speed
Postby bluebyu » February 23rd, 2019, 9:38 am
Not sure about your vessel,
Our Carver 440, the 6CTA8.3's must run a different RPMs for the engine sync to work properly.
Hope this helps
Users browsing this forum: No registered users and 5 guests
